Add mass in iParts
Add mass in iParts
johannes_santos
Add mass in iParts
johannes_santos
Hello, I have a question, I am making a iParts according to a catalog, I have to put the weight appears here, with the help i found this code
doc = ThisDoc.Document
customPropertySet = doc.PropertySets.Item("Inventor User Defined Properties")
prop = customPropertySet.Item("mymassoverride")
iProperties.Mass = prop.Value
But the units dont come out whit decimal.
A.Acheson
Hi @johannes_santos
Your going to have issues setting the override of the mass for each member. You can actually only set the override for the whole factory this is the same result manually or by using code. So the only way to get the mass correct is to actually model the ipart accurately and or adjust the material density etc or perform some operation on the part that changes the mass and can be set through the table.
Maybe you might consider modelstates or as another extreme workaround publish to CC then place as standard and manually override the mass.
Member 1
Member 2
Regards
Alan
johannes_santos
Ok thank for your help
