Add iProperties with a loop and arraylist
DFitting
DFitting
I am attempting to write some code to create multiple iProperties in my model from the idw. The parameters are in an arraylist and I would like to use a loop to run through the arraylist but I keep getting an error.  I would like to use a loop so I don't have to write out a try catch for each iProperty as the list is continually growing.
my code is a little confusing as the list is called oParameterList I should have named it oPropertyList. I intend to fix this
SyntaxEditor Code Snippet
iLogicVb.UpdateWhenDone = True
Dim odrawdoc As DrawingDocument
odrawdoc = ThisApplication.ActiveDocument
Dim userParams As UserParameters = odrawdoc.Parameters.UserParameters
customIDWPropertySet = odrawdoc.PropertySets.Item("Inventor User Defined Properties")
'Look at the model file referenced in the open document
Dim docFile As Document
If ThisDoc.ModelDocument IsNot Nothing Then
docFile = ThisDoc.ModelDocument
Else
MessageBox.Show("This drawing has no model reference", "iLogic")
Return
'format model file name
Dim FNamePos As Long
FNamePos = InStrRev(docFile.FullFileName, "\", -1)
Dim docFName As String
docFName = Right(docFile.FullFileName, Len(docFile.FullFileName) - FNamePos)
'define the property set
customPropertySet = docFile.PropertySets.Item("Inventor User Defined Properties")
'look for the custom propety and add it if not found
Dim oCode, oColor, oDesignPSI, oDIA, oEdition, oExBlast, oExCoat, oHydroChart,oInBlast, oInCoat, oLength, oLocation, oNPRO, oPWHT, oTestPSI As String
Dim oString As Object
Dim i As Integer = 0
Dim oParameterList As New ArrayList
oParameterList.Add("Code")
oParameterList.Add("Color")
oParameterList.Add("Design_Pressure")
oParameterList.Add("Design_Temp")
oParameterList.Add("Min_Design_Temp")
oParameterList.Add("DiameterIN")
oParameterList.Add("Edition")
oParameterList.Add("External_Blast")
oParameterList.Add("External_Coat")
oParameterList.Add("HYDRO CHART")
oParameterList.Add("Internal_Blast")
oParameterList.Add("Internal_Coat")
oParameterList.Add("Length_UL")
oParameterList.Add("Location")
oParameterList.Add("NAME PLATE RUB OFF")
oParameterList.Add("PWHT")
oParameterList.Add("Test_Pressure")
For Each oString In oParameterList
Try
prop = customPropertySet.Item(oParameterList(i))
'return
Catch
customPropertySet.Add("", oParameterList(i))
End Try
Try
prop = customIDWPropertySet.Item(oParameterList(i))
Catch
customIDWPropertySet.Add("", oParameterList(i))
End Try
i = i + 1
Next
JamieVJohnson2
Don't use ArrayList, use instead List(of T), where in your case List(of String) should work.  Also if you want a more robust method, separate the block of code for inserting a parameter into its own sub:
Sub Main 'ilogic requires this if you have more than one routine on a page, to tell it where to start.
     MyMainRoutine
End Sub
Public Sub MyMainRoutine
    'Define List - ParamNames as list(of string)
    'Populate List  - ParamNames.add(this), paramNames.add(that)...
    For each sParam as string in ParamNames
         booDidItWork as Boolean = WriteCustomProperty(paramName,paramValue,doc,overwrite?)
         If booDidItWork = False then MSGBOX("something went wrong")
     Next
End Sub
Public Function WriteCustomProperty(propName,propValue…)
try
     Do the thing
catch
    say something or skip it
end try
Return DidItWork
End Function
Personally I use this routine for that purpose:
    ''' <summary>
    ''' Add Custom iProperty To Inventor Document
    ''' </summary>
    ''' <param name="propName">Name of iProperty</param>
    ''' <param name="propValue">Value of iProperty</param>
    ''' <param name="invDoc">Document to work on</param>
    ''' <returns>True if file was changed</returns>
    ''' <remarks>Will look for property, if found, verify value, if different change value, if not found add property and value. Excludes Readonly files, and unsaved new files</remarks>
    Public Function WriteCustomProperty(ByVal propName As String, ByVal propValue As String, ByVal invDoc As Inventor.Document, Optional OverWriteProperty As Boolean = True) As Boolean
        Try
            Dim fi As New System.IO.FileInfo(invDoc.FullFileName)
            If fi.IsReadOnly Then Return False 'don't work with read-only files.  This gives the user control over which files to use and which to skip.
            Dim propSet As PropertySet = invDoc.PropertySets.Item("Inventor User Defined Properties")
            Dim custProp As Inventor.Property = FindiProperty(propSet.Name, propName, invDoc)
            eventLog += vbCrLf & invDoc.FullFileName
            'For Each prop In propSet
            '    If prop.Name = propName Then
            '        custProp = prop
            '        Exit For
            '    End If
            'Next
            If custProp Is Nothing Then
                custProp = propSet.Add(propValue, propName)
                filesEffected += 1
                eventLog += vbCrLf & "Added custom property: " & propName & ":  " & propValue
                Return True
            Else
                If Not String.IsNullOrWhiteSpace(custProp.Value) Then ' has a value first check if expression, then if regular property
                    If OverWriteProperty = True Then
                        If custProp.Expression.StartsWith("=") Then 'is expression
                            If custProp.Expression <> propValue Then
                                custProp.Value = propValue
                                filesEffected += 1
                                eventLog += vbCrLf & "Modified custom property: " & propName & ":  " & propValue
                                Return True
                        Else 'is value
                            If custProp.Value <> propValue Then
                                filesEffected += 1
                                Return True
                Else 'is emtpy - overwrite command does snot apply
                    filesEffected += 1
                    Return True
            Return False
        Catch ex As Exception
            'if property fails to write such as user does not check out or allow file to save, then retun without error.
            MsgBox("Can not write custom property: " & propName, MsgBoxStyle.SystemModal)
            Return False
        End Try
    End Function
Its way more than just add, but you can simplify it for your own needs.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
