Add iProperties value, print values and then before document save, remove values
jmcgookin
jmcgookin
Hello there.
I have the need to create a project # and project name value and place it on my title block. These values should only appear on a printed PDF file and not be saved on the drawing file. I need to have a global iProperty that allows me to enter the project # and project name and then any drawings I open after this is set, would populate these values on the drawing and remove them (suppress perhaps) before the drawing saves. Then for the next project, I would change these values and repeat the process. I know this can be done with coding, I am just to knew to iLogic and have only written basic code and forms to drive my skeletal models.
You may be asking yourselves, why do I want this "typically required" title block data to disappear before saving and not be stored with the detail drawing?? Reason is we have a library of parts that are not tied to any customer or project as they reside in our library. We print the clean document (without ties to customer or project data) and then hand write in the qty's and project data.
Any help and steps in the right direction would be greatly appreciated!
Thanks in advance to all of you,
Jeremy
JelteDeJong
You could make a text file with the data that you want to set to the iproperties. For example you create a text file with  2 lines. the first for the "Description" and the second for the "Part Number".  then you could make an iLogic rule that looks like this and use the trigger "After Open Documet" and "After Save Document".
Dim path As String = "C:\temp\projectdata.txt"
Dim lines As IEnumerable(Of String) = IO.File.ReadLines(path).ToArray()
iProperties.Value("Project", "Description") = lines(0)
iProperties.Value("Project", "Part Number") = lines(1)
then add a 2e rule that looks like this and use the trigger "Before Save Document"
iProperties.Value("Project", "Description") = ""
iProperties.Value("Project", "Part Number") = ""
Jelte de Jong
Blog: hjalte.nl - github.com
jmcgookin
This worked out great! Thank you. Had to make a minor change for my application as follows:
1st rule:
iProperties.Value("Custom", "Project Number") = lines(0)
iProperties.Value("Custom", "Project Name") = lines(1)
The "Custom" field change was required as the "Project" field pulls data from existing iProperties. This took me a few minutes to figure out why I was getting the errors I was.
Jeremy
