Add-in to create section automatically
thanh.trantuan
Message 1 of 18
thanh.trantuan
Hi everyone,
I try to write an add-in to create the sections automatically in Inventor drawing after basing the model
For example, I have a model like below picture with 3 longitudinal beams and 5 transverse beams
I base this model to Inventor drawing
and create sections like this
Could anyone suggest me the way to code the add-in to do this task automatically by using C#?
Many thanks
Replies (17)
Message 2 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@thanh.trantuan,
Please provide non confidential files to test the feasibility.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 3 of 18
thanh.trantuan
Dear CHANDRA,
Please see an attached model
Message 4 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@thanh.trantuan,
Thanks for sample files to investigate,
To section view in drawings, it is suggested to use workplanes as shown in below image. Later, same workplanes are used for creating section line and section views are added into drawing.
Using below VBA code, section views are added into drawing.
Sub Section_View()
    Dim oDoc As DrawingDocument
    Set oDoc = ThisApplication.ActiveDocument
    Dim oSheet As Sheet
    Set oSheet = oDoc.ActiveSheet
    Dim oView As DrawingView
    Set oView = oSheet.DrawingViews.Item(1)
    Dim oComp As Document
    Set oComp = oView.ReferencedDocumentDescriptor.ReferencedDocument
    Dim wpCnt As Integer
    Dim i As Integer
    i = 1
    Dim h As Integer
    h = 1
    Dim v As Integer
    v = 1
    Dim wp As WorkPlane
    For wpCnt = 4 To oComp.ComponentDefinition.WorkPlanes.count
        Set wp = oComp.ComponentDefinition.WorkPlanes.Item(wpCnt)
        Call oView.SetIncludeStatus(wp, True)
        Call oView.SetVisibility(wp, False)
        Dim oSketch As DrawingSketch
        Set oSketch = oView.Sketches.Add
        Call oSketch.Edit
        Dim oStartPt As Point2d
        Set oStartPt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Centerlines.Item(i).StartPoint.X, oSheet.Centerlines.Item(i).StartPoint.Y)
        Dim oStart As Point2d
        Set oStart = oView.SheetToDrawingViewSpace(oStartPt)
        Dim oEndPt As Point2d
        Set oEndPt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Centerlines.Item(i).EndPoint.X, oSheet.Centerlines.Item(i).EndPoint.Y)
        Dim oEnd As Point2d
        Set oEnd = oView.SheetToDrawingViewSpace(oEndPt)
        Dim oLine As SketchLine
        Set oLine = oSketch.SketchLines.AddByTwoPoints(oStart, oEnd)
        Dim oPt As Point2d
        If oEnd.X = oStart.X Then
            Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width - (10 * v), oView.center.Y)
            Call oSketch.GeometricConstraints.AddVertical(oLine)
            v = v + 1
        Else
            Set oPt = ThisApplication.TransientGeometry.CreatePoint2d(oView.center.X, (10 * h))
            Call oSketch.GeometricConstraints.AddHorizontal(oLine)
            h = h + 1
        Call oSketch.ExitEdit
        Call oSheet.DrawingViews.AddSectionView(oView, oSketch, oPt, kFromBaseDrawingViewStyle)
        i = i + 1
    Next
End Sub
To demonstrate the same, a screencast video is prepared and uploaded into below link.
https://autode.sk/2PI4wnq
The modified assembly with workplanes is attached with this post.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 5 of 18
thanh.trantuan
@chandra.shekar.g
Many thanks your reply and it's highly appreciate your great support I have some questions, could you share your thought
Firstly, in order to use your code, we have to create new planes which is constraint with existing structures. Could we have another way to do without create new planes like this. As you see, in the skeleton.ipt, these workplanes are created already, so can we use them to position the sketch lines
Secondly, can we constraint these sketches after creating them
Thirdly, in the section properties, the section depth is full, could it be set up with the distance (such as 50 mm or 100mm) to show the section at this area only.
Thanks & Best Regards
Message 6 of 18
GeorgK
Hello @chandra.shekar.g,
is it possible to get longer section lines (text should be outside of the geometry)?
Thank you Georg
Message 7 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@GeorgK,
At below code, extension of lines can be added depends on line type (Like Horizontal or Vertical).
        Dim oEnd As Point2d
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 8 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@thanh.trantuan,
Firstly, in order to use your code, we have to create new planes which is constraint with existing structures. Could we have another way to do without create new planes like this. As you see, in the skeleton.ipt, these workplanes are created already, so can we use them to position the sketch lines - The same code is modified to get planes from skeleton.ipt
Sub Section_View()
    Dim oSheet As Sheet
    Dim occ As ComponentOccurrence
    If oView.ReferencedDocumentDescriptor.ReferencedDocumentType = kAssemblyDocumentObject Then
        Dim oComp As AssemblyDocument
        Set occ = oComp.ComponentDefinition.Occurrences.ItemByName("Skeleton:1")
        Dim oSkeletonDoc As PartDocument
        Set oSkeletonDoc = occ.Definition.Document
    Else
        Exit Sub
    Dim i As Integer
    i = 1
    Dim h As Integer
    h = 1
    Dim v As Integer
    v = 1
    Dim wp As WorkPlane
    For Each wp In oSkeletonDoc.ComponentDefinition.WorkPlanes
        If wp.Name Like "T*" Or wp.Name Like "L*" Then
            Dim oProxy As WorkPlaneProxy
            Call occ.CreateGeometryProxy(wp, oProxy)
            Call oView.SetIncludeStatus(oProxy, True)
            Call oView.SetVisibility(oProxy, False)
            Call oSketch.Edit
            Dim oEnd As Point2d
            Dim oPt As Point2d
                v = v + 1
            Else
                h = h + 1
            i = i + 1
    Next
End Sub
Secondly, can we constraint these sketches after creating them - Yes, it constrained to vertical or horizontal.
Thirdly, in the section properties, the section depth is full, could it be set up with the distance (such as 50 mm or 100mm) to show the section at this area only. - Hoping the same answer to Geroge will help this.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 9 of 18
sam
Hi @chandra.shekar.g
thanks for this. Would you mind adding bit of comments to each part describing what the code does.
Best regards,
Sam
@chandra.shekar.g wrote:
@thanh.trantuan,
Sub Section_View()
    Dim oSheet As Sheet
    Else
        Exit Sub
    Dim i As Integer
    i = 1
    Dim h As Integer
    h = 1
    Dim v As Integer
    v = 1
    Dim wp As WorkPlane
            Call oSketch.Edit
            Dim oEnd As Point2d
            Dim oPt As Point2d
                v = v + 1
            Else
                h = h + 1
            i = i + 1
    Next
End Sub
Thanks and regards,
Message 10 of 18
thanh.trantuan
@chandra.shekar.g
Many thanks for your great support
Regarding to 3rd question, I mean the depth value when we edit section properties. Section depth is "distance" instead of "Full"
Besides, I try to arrange the section, break the alignment and rotate the vertical section
I see that in your code, the distance between each section can be controlled, so how about rotate these vertical sections?
Many thanks
Message 11 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@thanh.trantuan,
Try below code to change depth of section and rotate the section view.
Dim oSection As SectionDrawingView
            Set oSection = oSheet.DrawingViews.AddSectionView(oView, oSketch, oPt, kFromBaseDrawingViewStyle)
            oSection.SectionDepth = 127
            Call oSection.RotateByAngle(1.57, True)
Full modified code is as below.
Sub Section_View()
    Dim oSheet As Sheet
    Else
        Exit Sub
    Dim i As Integer
    i = 1
    Dim h As Integer
    h = 1
    Dim v As Integer
    v = 1
    Dim wp As WorkPlane
            Call oSketch.Edit
            Dim oEnd As Point2d
            Dim oPt As Point2d
                v = v + 1
            Else
                h = h + 1
            i = i + 1
    Next
End Sub
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 12 of 18
thanh.trantuan
@chandra.shekar.g
Many thanks for your support, it's all clear now
Message 13 of 18
thanh.trantuan
@chandra.shekar.g
Sorry, I just have one question that
If I use frame generator to create stiffener, so it means that there are no work planes at the position of stiffener (because frame generator generate beams from sketch line). I want to make sections at the position of stiffeners by picking the part's edge (step 1) but it cannot work. Can you suggest me to do this task like this?1.JPG
Many thanks
Message 14 of 18
thanh.trantuan
@chandra.shekar.g
Could you please take a look this question and give me any supports
Message 15 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@thanh.trantuan,
Are you trying through UI?
Please provide non confidential drawing files and supporting files to test the feasibility.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 16 of 18
thanh.trantuan
@chandra.shekar.g
I attached model here, please take a look
Besides, if it's possible, may I ask for help about customizing the text format of the section view like picture below by using VBA
there are 2 options, firstly is change single text of the section view, secondly is change all text of the all section view within the drawing sheet.
Many thanks
Message 17 of 18
chandra.shekar.g
Autodesk Support
Autodesk Support
@thanh.trantuan,
Try below code to change the label of drawing view.
            oSection.Label.FormattedText = "<StyleOverride Bold='True' Underline='True' FontSize='0.8'>SECTION <DrawingViewName/>-<DrawingViewName/></StyleOverride><Br/>SCALE <DrawingViewScale/>"
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 18 of 18
thanh.trantuan
@chandra.shekar.g
Thank you so much, so how about the question
"Sorry, I just have one question that
If I use frame generator to create stiffener, so it means that there are no work planes at the position of stiffener (because frame generator generate beams from sketch line). I want to make sections at the position of stiffeners by picking the part's edge (step 1) but it cannot work. Can you suggest me to do this task like this?"1.JPG
could you give me any clues about this?
Thanks in advance
