ADD-in from worklocaties vault
JanHermans
JanHermans
Hi everyone,
Is it possible to launch an add-in from the workspace? This is automatically synchronized on every PC. Everyone must use the same add-in.
Sometimes I have to update the add-in with new data once a month.
Currently, I have to do this separately on each PC (about 20 PCs). I want to automate this. Can someone tell me if this is possible and what the best approach is?
Regards, Jos
TylerWarner33
There is an ongoing, similar conversation in this thread (Self Updating Add-In).
If this answered your question, click 'Accept Solution'.
If this was helpful, click 'Like'.
Tyler Warner
marcin_otręba
sure it is possible, i am using it this way.. in addin file you must give whole .dll file path like in red line below:
<Addin Type="Standard">
  <!--Created for Autodesk Inventor Version 19.0-->
  <ClassId>...</ClassId>
  <ClientId>...</ClientId>
  <DisplayName>XXX</DisplayName>
  <Description>XXX</Description>
  <Assembly>serverpath\name.dll</Assembly>
  <LoadOnStartUp>1</LoadOnStartUp>
  <UserUnloadable>0</UserUnloadable>
  <Hidden>0</Hidden>
  <SupportedSoftwareVersionGreaterThan>17..</SupportedSoftwareVersionGreaterThan>
  <DataVersion>1</DataVersion>
  <UserInterfaceVersion>1</UserInterfaceVersion>
</Addi
here is like it should look like:
<Assembly>C:\Vault\ustawienia\Skrypt\Bin\create_files.dll</Assembly>
Hi, maybe you want to vote my:
Ideas
or check my apps:
DrawingTools   View&ColoringTools   MRUFolders
