Add-In doesn't load in Inventor??
Dear All,
I am trying to change my VBA code to Add-In, I already install SDK> Developertools.msi and wizards.msi. I create a new file with InventorAddIn template. And I build it successfully.
Then I open Inventor -> Add-Ins and nothing happen................
My system is 64bit. I've already read the following topic, but I don't really understand.......
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Inventor-2011-Add-in-not-loading/m-p/2...
I already double click to the "regasm" file........but nothing changes within Inventor Add-Ins.........
Has anybody who use Inventor 2011 sp1 64 bit and VB.Net Express 2008 created an Add-In already?????
Please show me how to set up..............
I got the solution.........that is, we must open the Regasm by CMD..........and copy the dll file to the same folder, after that
run
c:\windows\microsoft.net\framework64\v2.5xxxx\regasm.exe /codebase AddInName.dll
Does anyone know how to create a Bat file.........??????
Hi
This is one way to create a cmd file that will register the add-in. Create the installation file, name it something like InventorAddinInstall.cmd, and put it in the same folder as your add-in.
You will of course have to change the name of the add-in in the file... (4th row from the bottom).
/Stefan Olofsson
@echo off
setlocal
set InstDir=%~dp0
set InstFlag=%1
if /i "%PROCESSOR_ARCHITECTURE%"=="amd64" goto reg64
if /i "%PROCESSOR_ARCHITEW6432%"=="amd64" goto reg64
if /i "%PROCESSOR_ARCHITECTURE%"=="IA64"  goto reg64
if /i "%PROCESSOR_ARCHITEW6432%"=="IA64"  goto reg64
echo Registering 32-bit version of addin for Inventor
set regasm=%windir%\Microsoft.Net\Framework\v2.0.50727\regasm.exe
goto lblRegister
:reg64
echo Registering 64-bit version of addin for Inventor
set regasm=%windir%\Microsoft.Net\Framework64\v2.0.50727\regasm.exe
goto lblRegister
:lblRegister
%regasm% %InstFlag% /codebase "%InstDir%AddInName.dll"
goto lblExit
:lblExit
exit /b 0
thank you, It work well.
Does anyone know how to add RibbonTab for all environment
Recently, I can only add one
If I add more, Add-In doesn't work.
First, I use For....Next but it didn't work. Then I use directly and it didn't work too.
At last, I change to the simplest way, and it only works for one environment.
Dim oRibbon(3) As Inventor.Ribbon
'oRibbon(0) = m_inventorApplication.UserInterfaceManager.Ribbons.Item("Part")
oRibbon(1) = m_inventorApplication.UserInterfaceManager.Ribbons.Item("Assembly")
'oRibbon(2) = m_inventorApplication.UserInterfaceManager.Ribbons.Item("Drawing")
'oRibbon(3) = m_inventorApplication.UserInterfaceManager.Ribbons.Item("Presentation")
'create the newTab
Dim NewTab(3) As Inventor.RibbonTab
'NewTab(0) = oRibbon(0).RibbonTabs.Item("ABC")
NewTab(1) = oRibbon.RibbonTabs.Add("NewTab", "NewTabForAssembly", m_ClientID, "id_GetStarted", False)
'NewTab(2) = oRibbon(1).RibbonTabs.Add("New", "NewTabForDrawing", m_ClientID, "id_GetStarted", False)
 'NewTab(3) = oRibbon(1).RibbonTabs.Add("New", "NewTabForPresentation", m_ClientID, "id_GetStarted", False)
'create the new panel on the New Tab
Dim NEWPanel(3) As Inventor.RibbonPanel
'NEWPanel(0) = NewTab(0).RibbonPanels.Add("NEW IT", "NEWITPanel", m_ClientID)
NEWPanel(1) = NewTab.RibbonPanels.Add("NEW IT", "NEWITPanel", m_ClientID)
'NEWPanel(2) = NewTab(2).RibbonPanels.Add("NEW IT", "NEWITPanel", m_ClientID)
'NEWPanel(3) = NewTab(3).RibbonPanels.Add("NEW IT", "NEWITPanel", m_ClientID)
'NEWPanel(0).CommandControls.AddButton(m_Button0Def, True, True)
NEWPanel(1).CommandControls.AddButton(m_Button0Def, True, True)
'NEWPanel(2).CommandControls.AddButton(m_Button0Def, True, True)
 'NEWPanel(3).CommandControls.AddButton(m_Button0Def, True, True)
