add-in and button execution problem
I have an add-in utilizing the following code. The
problem I am having is that after exeuting the button and loading the form a new
instance of the same form opens everytime I hit the spacebar. Does anyone know
how to ensure only 1 instance of the form can be loaded at a time. Thanks in
advance for any help.
Private
color=#0000ff size=2>Sub
oButtonProps_OnExecute(
color=#0000ff size=2>ByVal
Context
color=#0000ff size=2>As
Inventor.NameValueMap)
color=#0000ff size=2>Handles
oButtonProps.OnExecute
On
color=#0000ff size=2>Error
size=2>GoTo
err_oButtonProps
Dim oDoc
Document
On
size=2>Resume
size=2>Next
oDoc = Inv.ActiveDocument
If Err.Number
Then
Exit
End
color=#0000ff size=2>If
' Check if File is read only and see if
user wants to check out
Dim RO
size=2>String
RO = ROnly(oDoc.FullDocumentName)
If RO = 0
color=#0000ff size=2>Or
RO = 2
size=2>Or
RO = 32
size=2>Or
RO = 34
size=2>Then
Else
Check_Out()
End
mIV_Properties =
New
IV_Properties
mIV_Properties.Visible =
size=2>True
mIV_Properties.Show()
mIV_Properties =
Nothing
size=2>
err_oButtonProps:
End
Scott A.
McCoy
Pressing the space bar executes the previous command again, in this case
it's your command. Is this also happening when entering a space while
typing data into your form? If that's the case then you need to make sure
that you set Inventor as the parent of your dialog. This will also make
sure that your dialog displays on top of Inventor and if Invntor is
minimized it will be minimized too.
Even with correctly setting the parenting you can still have the problem if
the user executes your command again, either using space or another method.
The correct thing to do is to wrap your command with an InteractionEvents
object. Typically this is used to handle selections and some other command
related things. However an important component of the InteractionEvents
object is that it gives your command correct command behavior. That is if
another command is executed, yours will be terminated. This is how all of
Inventor's commands behave.
Brian Ekins
Autodesk Inventor API
etckerry
I am having the same problem (typing in a text box in the form, and when I hit space bar another form opens). I am not setting my form's parent property to Inventor. How do I do this? When I set Parent = InventorApp (InventorApp has type Inventor.Appliation) I get an exception because I'm trying to assign an System.___COMObject to a System.Windows.Form.Control. I understand why I am getting this error, but I can't find a way to extract Inventor's form from the Inventor.Application object. I am sure someone has run into this problem before...
Kerry
It's not as easy as you would expect using
.Net.  The attached txt file has some sample code that demonstrates
this.
Brian Ekins
href="http://blogs.autodesk.com/modthemachine">http://blogs.autodesk.com/modthemachine
martin_mmj
This is very important information for me too.
Thanks for sample Brian, works fine.
Martin
