Add iLogic to C#
Add iLogic to C#
Daan_M
Add iLogic to C#
Daan_M
I have a problem adding iLogic and also the dll's give me a warning, dont know what i'm doing wrong...
void AddiLogic()
            string MyRuleName = "rulename";
            string iLogicAddinGuid = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}";
            ApplicationAddIn iLogicAddin;
            object iLogicAutomation = null;
            try
                iLogicAddin = _invApp.ApplicationAddIns.ItemById[iLogicAddinGuid];
                iLogicAutomation = iLogicAddin.Automation;
            catch (Exception ex)
                MessageBox.Show("Unable to access iLogic addin " + ex.Message);
            try
                iLogicAutomation.RunRule(oDoc, MyRuleName);
            catch
                MessageBox.Show("There is no rule called " + MyRuleName);
ianteneth
Hi @Daan_M,
I think the error is telling you that you need to define the type of the iLogicAutomation object. In the line below you are declaring iLogicAutomation as a generic object. And the generic Object class doesn't have a method called RunRule. What is the type of iLogicAutomation? Replace the word 'object' in the line below with the actual type of the iLogicAutomation object. I hope this helps!
You could alternatively replace the above line with this maybe?
var iLogicAutomation;
Daan_M
Thank you for the reply, i changed it and get the following error in the line where i declare the local variable:
" Error CS0818 Implicitly-typed variables must be initialized "
 void AddiLogic()
            string MyRuleName = "cmdRead";
            var iLogicAutomation; //<- HERE
            try
            try
                iLogicAutomation.Runrule(oDoc, MyRuleName);
            catch
ianteneth
I found a link to an earlier post that had this problem. This line seems to be the fix? Try using "dynamic" instead of "var".
dynamic iLogicAutomation = null;
https://forums.autodesk.com/t5/inventor-customization/call-ilogic-from-net-c-inventor-2018/m-p/85226...
