Add Border to Cell Range.
C_Haines_ENG
Message 1 of 11
C_Haines_ENG
I have tried everything VBA related to doing this and nothing fruitful has come up without providing me some sort of error. The code below is what seems to create the smallest error, however it doesn't seem to work none the less.
.Range("B2:E2").Borders(xlEdgeBottom).Weight = xlMedium
I would like to be able to add a thick border to the bottom of a cell range.
As a bonus, does anyone know how to center and change the width of cells? Or bold cells?
Replies (10)
Message 2 of 11
BM_Ashraf
The code you shared is working fine .
Sub Test_XL()
Dim excelApp As excel.Application
Dim ws As WorkSheet
Dim owb As Workbook
On Error Resume Next
Set excelApp = GetObject(, "Excel.Application")
' Try to connect to a running instance of Excel.
    If Err Then
        Err.Clear
        ' Couldn't connect so start Excel.  It's started invisibly.
        Set excelApp = CreateObject("Excel.Application")
        If Err Then
            MsgBox "Cannot access excel."
  excelApp.Visible = True
  excelApp.DisplayAlerts = False
  Set owb = excelApp.Workbooks.Add
  Set ws = owb.Worksheets(1)
    With ws
    .Range("B2:E2").value = "MechDS" & "Email:zezo7790@gmail.com"
    .Range("B2:E2").Font.Bold = True
    .Range("B2:E2").Columns.AutoFit
    .Range("B2:E2").Borders(xlEdgeBottom).Weight = xlThick
    End With
  'excelApp.Quit
End Sub
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Blue Mech
Add-ins for Inventor!
Message 3 of 11
C_Haines_ENG
Your code does not seem to work for me, ive posted the code ive written below:
'define the file to create/open
xlsPath = "C:\BOM Calculator\Test.xlsx"
'define Excel Application object
'set Excel to run visibly, change to false if you want to run it invisibly
'suppress prompts (such as the compatibility checker)
'check for existing file
If Dir(xlsPath) <> "" Then
'workbook exists, open it
excelWorkbook = excelApp.Workbooks.Open(xlsPath)
ExcelSheet = excelWorkbook.Worksheets(1)
Else
'workbook does NOT exist, so create a new one
excelWorkbook = excelApp.Workbooks.Add
'Insert data into Excel.
With excelApp
	If .Range("A1").Value < 2
		RowNum = 2
	   .Range("A1").Value = 2
	Else
		RowNUM = .Range("A1").Value
			.Range("B" & RowNum) = iProperties.Value(modelName,"Project", "Part Number")
			.Range("C" & RowNum) = iProperties.Value(modelName, "Project", "Description")
End With
'set all of the columns to autofit
excelApp.Columns.AutoFit
'save the file
excelWorkbook.SaveAs(xlsPath)
''close the workbook and the Excel Application
''uncomment if you want to close the xls file at the end
excelWorkbook.Close
excelApp.Quit
excelApp = Nothing
Message 4 of 11
tyler.warner
Beginning at line 26, you're inserting the data into the Excel application. Review MechDS' code from above. You want to be working on a specific worksheet. You had defined the worksheet if there was an existing one (line 17) but didn't create one otherwise and then you're not actually using it in your code.
Here's the full documentation for the borders & cells:
Excel Object Model on Borders (link)
Excel Object Model on Cells (link)
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
Message 5 of 11
C_Haines_ENG
Where do I have to declare this, I keep getting random errors.
.Worksheets(1).Range("B" & RowNum & ":" & "G" & RowNum).Borders(xlEdgeBottom).Weight = xlMedium
The documentation states that this is acceptable but it still doenst work.
Message 6 of 11
tyler.warner
What are the errors that you're getting? Please provide images.
Message 7 of 11
A.Acheson
Hi @C_Haines_ENG
Implementing in VB.NET is a little harder than VBA. You will have to access objects in more depth adding the enumeration.
For Example this is how to access your original snippet in VB.NET and here is the link to the Weight enumeration
and the Border Enumeration
.Range("B2:E2").Borders(XlBordersIndex.xlEdgeBottom).Weight = XlBorderWeight.xlMedium
 Here is the working method in VB.Net
AddReference "Microsoft.Office.Interop.Excel" 'To use excel
Imports Microsoft.Office.Interop 'To use excel
Imports Microsoft.Office.Interop.Excel 'To use excel
Dim excelApp As Excel.Application = GetObject(, "Excel.Application") Try excelApp = CreateObject("Excel.Application") Catch MsgBox ("Cannot access excel.") End Try excelApp.Visible = True excelApp.DisplayAlerts = False Dim oWb As Workbook = excelApp.Workbooks.Add Dim oWs As Worksheet = oWb.Worksheets(1) With oWs .Range("B2:E2").Value = "This is a new Excel value" .Range("B2:E2").Columns.AutoFit Try .Range("B2:E2").Borders(XlBordersIndex.xlEdgeBottom).Color = RGB(255, 0, 0) .Range("B2:E2").Borders(XlBordersIndex.xlEdgeBottom).Weight = XlBorderWeight.xlMedium Catch MessageBox.Show ("Error applying border.","iLogic") End Try End With
Regards
Alan
Message 8 of 11
C_Haines_ENG
Here is the error im receiving:
Error on line 110 in rule: BOMCalc, in document: 751434.dwg
Exception from HRESULT: 0x800A03EC
Below is how "excelApp" is being defined.
'excelWorkbook = excelApp.Workbooks.Open(xlsPath)
Else
Message 9 of 11
C_Haines_ENG
Hey you solved it!
That did the trick. Thank you!
Is there a form where I can see all the different options? Like outside boxes, line weights etc?
Would you also know how to format colums/cells, id like to center a column but the code ive found seems to have the same problems.
Message 10 of 11
A.Acheson
Here is the RangeHorizontalAlignment and here is how a handy post discussing how to declare the value xlCenter
.Range("B2:E2").HorizontalAlignment = Excel.Constants.xlCenter
 Regarding a form unfortunately I don't. Internet searching is your best bet. Find it in VBA then check the documentation for how to implement in VB.NET
Regards
Alan
Message 11 of 11
C_Haines_ENG
Double win, thanks a ton!
