Add and format parameter to all parts in assembly
DewayneH
DewayneH
I'm working on an external rule to add and format a set of parameters to all parts within an assembly.
I'm trying to check if the parameter exists then add and format if it doesn't.
I've found a few examples and unsuccessfully tried to piece something together.
The attached code runs without error, but it doesn't affect the parts in the assembly. It does nothing.
Suggestions?
Dim oAssDoc As AssemblyDocument = ThisDoc.Document
Dim oDoc As Document
For Each oDoc In oAssDoc.AllReferencedDocuments
	If oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		Dim oParams As Inventor.Parameters = oDoc.ComponentDefinition.Parameters
		Dim oUserParams As UserParameters = oParams.UserParameters
		oMyParameter = oUserParams
		Try
			'Try to Change value Of param
			Parameter("RMCat") = Parameter("RMCat")
		Catch
			'Create Param as it doesn't exist
			oParameter = oMyParameter.AddByValue("RMCat", "Plate-Sheet", UnitsTypeEnum.kTextUnits)
			MultiValue.SetList("RMCat", "Plate-Sheet", "Check Plate", "Round", "Tube", "Rubber", "None")
			Parameter.Param("RMCat").Comment = "Raw Material Category"
		End Try
Next
Dewayne
Inventor Pro 2023
Vault Pro 2023
FINET_Laurent
Maybe this ? For all parts referenced in the assembly :
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oLeafOcc As ComponentOccurrence
Dim oParameter As UserParameter
Dim oString() As String = {"""RMCat""", """Plate-Sheet""", """Check Plate""","""Round""","""Tube""","""Rubber""","""None"""} 'Create multi-value list
For Each oLeafOcc In oDoc.ComponentDefinition.Occurrences.AllLeafOccurrences
	Try 'Try to change parameter value
		oLeafOcc.Definition.Parameters.UserParameters.Item("RMCat").Value = "RMCat"	'Change to the desired value
	Catch 'Create the parameter
		oParameter = oLeafOcc.Definition.Parameters.UserParameters.AddByValue("RMCat", "Plate-Sheet", UnitsTypeEnum.kTextUnits)
		oParameter.ExpressionList.SetExpressionList(oString,False)
		oParameter.Comment = "Raw Material Category"
	End Try
Next
Hope this helps,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
There is an app in the App Store called Fyenite that allows you to push global parameters and/or properties to any number of parts, assemblies, and drawings. Might be worth checking out!
Cheers,
Jeff
Curtis_Waguespack
Hi @DewayneH
here's another method
Sub Main
	Dim oOccs As ComponentOccurrences = oDoc.ComponentDefinition.Occurrences
	Call TraverseAssembly(oOccs)
End Sub
Function TraverseAssembly(oOccs As ComponentOccurrences)
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oOccs
		'process subassemblies
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		ElseIf oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
			Call AddParam(oOcc)
	Next
End Function
Sub AddParam(oOcc As ComponentOccurrence)
	oDoc = oOcc.Definition.Document
	Try
		'Try to get the parameter
		oParameter = oUserParams.Item("RMCat")
	Catch
		oParameter = oUserParams.AddByValue("RMCat", "Plate-Sheet", UnitsTypeEnum.kTextUnits)
	End Try
	MultiValue.SetListInComponent(oOcc.name, "RMCat", "Plate-Sheet", "Check Plate", "Round", "Tube", "Rubber", "None")
End Sub
I hope this helps.
Curtis
DewayneH
Curtis,
As usual, works beautifully.
I added some additional parameters with formatting, and it's works great.
Thanks!
Dewayne
Inventor Pro 2023
Vault Pro 2023
