Add a Button to Export tab of Application Menu in Inventor
Need some help for adding a button to "Export" tab of Application Menu of Inventor. I am using Vc++.
The information that i found is from UserInterfaceManager i could get CommandControls and add a button/ Seperator here. Need to add this inside the "Export" tab.
I would be glad if anybody could help me with the same.
I have just finished doing the same in C#:
Application.UserInterfaceManager.FileBrowserControls["Export"].ChildControls.AddButton(exportButton.ButtonDefinition, true, true, "", false);
Thank You for your reply.
I tried implementing the same in C++(VC). Please find the bellow code snap:
CComPtr<CommandControls> pcmdControls;
pcmdControls = pUserInterfaceMgr->FileBrowserControls;
CComPtr<CommandControl> pcmdControl;
hr = pcmdControls->get_Item(CComVariant(_T("Export")),&pcmdControl);
CComPtr<CommandControls> pcmdcontrolsExp;
hr = pcmdControl->get_ChildControls(&pcmdcontrolsExp);
hr =pcmdcontrolsExp->AddButton(pDrawSlotCmdBtnDef,true, true, "",false);
But this fails.. Request you to let me know where is the problem. Thank you for the help.
Hey,
Its working. I Kept the Internal Name blank while adding the Button to the child control.
Thanks.
-Kalyani
