This rule is taken from my blog. (www.hjalte.nl) There you will also find other rules that will auto-dimension holes and bend dimensions.
Public Class ThisRule
' This code was written by Jelte de Jong
' and published on www.hjalte.nl
Private _doc As DrawingDocument
Private _sheet As Sheet
Private _view As DrawingView
Private _intents As List(Of GeometryIntent) = New List(Of GeometryIntent)()
Sub Main()
_doc = ThisDoc.Document
_sheet = _doc.ActiveSheet
_view = ThisApplication.CommandManager.Pick(
SelectionFilterEnum.kDrawingViewFilter,
"Select a drawing view")
CreateIntentList()
createHorizontalOuterDimension()
createVerticalOuterDimension()
End Sub
Private Sub createHorizontalOuterDimension()
Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.X)
Dim pointLeft = orderedIntents.First
Dim pointRight = orderedIntents.Last
Dim textX = pointLeft.PointOnSheet.X +
(pointRight.PointOnSheet.X - pointLeft.PointOnSheet.X) / 2
Dim textY = _view.Position.Y + _view.Height / 2 + 2
Dim pointText = ThisApplication.TransientGeometry.CreatePoint2d(textX, textY)
_sheet.DrawingDimensions.GeneralDimensions.AddLinear(
pointText, pointLeft, pointRight, DimensionTypeEnum.kHorizontalDimensionType)
End Sub
Private Sub createVerticalOuterDimension()
Dim orderedIntents = _intents.OrderByDescending(Function(s) s.PointOnSheet.Y)
Dim pointLeft = orderedIntents.Last
Dim pointRight = orderedIntents.First
Dim textY = pointLeft.PointOnSheet.Y +
(pointRight.PointOnSheet.Y - pointLeft.PointOnSheet.Y) / 2
Dim textX = _view.Position.X - _view.Width / 2 - 2
pointText, pointLeft, pointRight, DimensionTypeEnum.kVerticalDimensionType)
End Sub
Private Sub addIntent(Geometry As DrawingCurve, IntentPlace As Object, onLineCheck As Boolean)
Dim intent As GeometryIntent = _sheet.CreateGeometryIntent(Geometry, IntentPlace)
If intent.PointOnSheet Is Nothing Then Return
If onLineCheck Then
If (IntentIsOnCurve(intent)) Then
_intents.Add(intent)
Else
End Sub
Private Function IntentIsOnCurve(intent As GeometryIntent) As Boolean
Dim Geometry As DrawingCurve = intent.Geometry
Dim sp = intent.PointOnSheet
Dim pts(1) As Double
Dim gp() As Double = {}
Dim md() As Double = {}
Dim pm() As Double = {}
Dim st() As SolutionNatureEnum = {}
pts(0) = sp.X
pts(1) = sp.Y
Try
Geometry.Evaluator2D.GetParamAtPoint(pts, gp, md, pm, st)
Catch ex As Exception
Return False
End Try
Return True
End Function
Private Sub CreateIntentList()
For Each oDrawingCurve As DrawingCurve In _view.DrawingCurves
Select Case oDrawingCurve.ProjectedCurveType
Case _
Curve2dTypeEnum.kCircleCurve2d,
Curve2dTypeEnum.kCircularArcCurve2d,
Curve2dTypeEnum.kEllipseFullCurve2d,
Curve2dTypeEnum.kEllipticalArcCurve2d
addIntent(oDrawingCurve, PointIntentEnum.kCircularTopPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kCircularBottomPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kCircularLeftPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kCircularRightPointIntent, True)
addIntent(oDrawingCurve, PointIntentEnum.kEndPointIntent, False)
addIntent(oDrawingCurve, PointIntentEnum.kStartPointIntent, False)
Case _
Curve2dTypeEnum.kLineCurve2d,
Curve2dTypeEnum.kLineSegmentCurve2d
Case _
Curve2dTypeEnum.kPolylineCurve2d,
Curve2dTypeEnum.kBSplineCurve2d,
Curve2dTypeEnum.kUnknownCurve2d
' Unhandled curves types
Case Else
End Select
Next
End Sub
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
