adaptive workpoint assembly -> redefine with geometry from another part
Sergio.D.Suárez
Mentor Mentor
Sergio.D.Suárez
Hi, I have a question that I have not been able to solve. I have two pieces inside an assembly. I would like with an Ilogic rule, from the assembly to select a workpoint from the part (Adaptative), define it as adaptive, and then redefine it with a vertex of the geometry of another part (Base). I need to solve this simple task and then apply it to a more complex problem, where several points of arbitrary orientation define the main geometries of my assembly.
I tried to make a code, which did not work for me.
Sub Main()
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
Dim oPart As ComponentOccurrence
'Pick part occurrence
oPart = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyLeafOccurrenceFilter, "Seleccione Pieza")
	If oPart Is Nothing Then
		Exit Sub
	Else
		oPart.Adaptive = True
		Dim oDef As PartComponentDefinition
	    oDef = oPart.Definition
Dim MidA As WorkPoint = oDef.WorkPoints.Item("Med1")
MidA.Adaptive = True
overt = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartVertexFilter, "Seleccione Vertice")
MidA.SetByPoint(overt)
End Sub
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Sergio.D.Suárez
Trying to follow another way, I have managed to develop this code, which has solved the problem. If a similar problem occurs to someone, it may be useful
Sub Main()
		Exit Sub
	Else
		oPart.Edit
		Dim oMed1 As WorkPoint
		oMed1 = oDef.WorkPoints.Item("Med1")
		Dim oCommand As CommandManager
		oCommand = ThisApplication.CommandManager
		oCommand.DoSelect(oMed1)'Select workpoint
		Dim oControlDef As ControlDefinition ' Get control definition for the line command.
		oControlDef = oCommand.ControlDefinitions.Item("RedefineFeatureWrapperCmd")
		oControlDef.Execute2(True)  ' Execute the command.
		oPart.ExitEdit(63746) 'kExitToParent
End Sub
Mechanical Designer
