ActiveEditDocument.GraphicsDataSetsCollection.Add2
mikazakov
mikazakov
Xiaodong Liang wrote the article:
http://adndevblog.typepad.com/manufacturing/2012/06/save-clientgraphics-information-along-with-the-d...
But, method:
return exception
Why?  Xiaodong Yang joked?
Sub Test()
Dim doc As PartDocument
Set doc = ThisApplication.ActiveEditDocument
Dim GetGUID As String
GetGUID = Mid$(CreateObject("Scriptlet.TypeLib").GUID, 2, 36)
Dim oGraphicsData As GraphicsDataSets
Set oGraphicsData = ThisApplication.ActiveEditDocument.GraphicsDataSetsCollection.Add2(GetGUID, True)
End Sub
xiaodong_liang
Autodesk Support
Autodesk Support
I wrote the blog long time ago, testing with old releases. While in the latest Inventor, the Add2 method is re-defined as _Add2.  And this is a hidden method, you need to switch on [show hidden methods] of object browser to see it. So, in VBA, the code could be as below. I will update that blog.
Thanks for soptting this.
Sub Test()
Set oGraphicsData = ThisApplication.ActiveDocument.GraphicsDataSetsCollection.[_Add2](GetGUID, True)
End Sub
mikazakov
Thank you for your answer.
