Activating Project working
ngocson8335
ngocson8335
Dear all,
I would like to get the workspace of an activating project in Inventor. But I can not find the right API to get it.
Please support me in this case.
Thank you.
Ngoc Son
Autodesk User
Accepted solutions (3)
Ralf_Krieg
Hello
Try
ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath
R. Krieg
RKW Solutions
www.rkw-solutions.com
ngocson8335
Thanks Sir, but it replied in Nothing. I do not know why. I am using VB.NET
Ngoc Son
Autodesk User
Ralf_Krieg
Hello
It is possible that the active project had no workspacepath defined. Can you manually verify that this path is set in projectmanager? If this path is not set, Inventor looks next in the
ThisApplication.DesignProjectManager.ActiveDesignProject.WorkgroupPaths
If there is also not set a path, Inventor takes documents folder in user profil.
R. Krieg
RKW Solutions
NachoShaw
Dim _InvApp as Inventor.Application
Dim oDesignProjectMgr As Inventor.DesignProjectManager = _Invapp.DesignProjectManager
Dim oProject As Inventor.DesignProject = oDesignProjectMgr.ActiveDesignProject
Dim ProjectName As String = oProject.Name
Dim ProjectPath As String = oProject.WorkspacePath
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
