Activate Panel Button using ilogic
Message 1 of 1
I am pretty new at ilogic and need a little help.
I need to know how to activate the Sheet Metal Default Dialogue box using ilogic.  This is the code i have is as follows:
If SheetMetal.GetActiveStyle() = "Default" Then
MessageBox.Show("You cannot use DEFAULT THICKNESS; Please choose correct Thickness from Sheet Metal Rule.", "Default is Active")
ThisApplication.CommandManager.ControlDefinitions.Item("Sheet_Metal_Defaults")
This is the line that is not working.  My syntax is probably way off.
Replies (0)
