Action Rules when Using Save and replace
Darkforce_the_ilogic_guy
Advisor Advisor
it there a way to get Action rules to run on an part or assembly when you are using Save and Replace If I use copy design, some thing like Reset Reversion number is done to the file. Is there a way to run Action rule when using save and replace ? or make an illogic code run on a part that is just create by save and Replace ?
Sergio.D.Suárez
Hi, Excuse me if I have not interpreted you.
Are you talking about adding event triggers to the ilogic when the document is saved?
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Kind of.. when we use copy design we are using action rule...that reset revision number to 0 , and some custom properties, that we use in your system .. our problem is that sometime it a lot easier to use save and replace but there is no action rule there so no reset of any properties, so it just copy the ones form the part it copy.
I do not want it to do all the time I save a part only when the part was just create by the save and replace function
chandra.shekar.g
Autodesk Support
Autodesk Support
@Darkforce_the_ilogic_guy,
On calling 'Save and replace' command, FileUIEvents.OnPopulateFileMetadata Event is triggered. I think, an addin can be triggered this event. In this event, document is available to reset revision number and custom iProperties. For more details, refer below help documentation link.
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-2E992173-A195-4588-B76F-6F156773FAE9
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
