Action based on color of part face
I am using Inventor 2016.
I am trying to perform an action based on the color of a part's face.  The code below checks each face - the If statement (obviously not real) needs to check the color of the current face but I cannot figure out how to write the statement.  Can someone help?
Dim oDoc as PartDocument = ThisDoc.Document
Dim oDef as PartComponentDefinition = oDoc.COmponentDefinition
Dim area As Double = 0.0
For Each oSurfBody As SurfaceBody In oDef.SurfaceBodies
	For Each oFace As Face In oSurfBody.faces
		If color Of face = "Canary" Then ' How to write this line to check face color?			Dim oEval As SurfaceEvaluator = oFace.Evaluator
			area = area + oEval.Area
	Next
Next
' Do something with area value
rikard.nilsson
To get the name.. Use
oFace.Appearance.DisplayName
Regards
Rikard
Thank you.  That was what I needed.
