Acessing iProperties from VB
I am brand new to both iLogic and MS Visual Studio 2010 Express. I am trying to find out how to access iProperties from VB. What I want to do is create a dialogue box in MS VS that has checkboxes and combo lists that will allow a user to change many iProperties at once instead of having to wade through a long series of dialogue boxes for individual iLogic rule dialogues. Specifically, I want to access the list of Materials that we created in our Style Library and display this list in a combo box so the user can select a specific material. Something like:
Public Class dlgCase
    Public Parameter As IParamDynamic
    Public MultiValue As IMultiValueParam
    Public ILogicVB As ILowLevelSupport
    Public vbMat As String
    Public vbMatList As ArrayList
Private Sub MAT_ComboBox1_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MAT_ComboBox1.SelectedIndexChanged
        vbMatList = ?????
        For Each vbMat_val As String In vbMatList
            MAT_ComboBox1.Items.Add(vbMat_val)
        Next
        MAT_ComboBox1.Text = vbMat
    End Sub
I know this is probably way wrong and violates any number of best programming practices, but I have to start somewhere. How do I assign the materials list from Inventor Style Library to the vbMatlist array where arll the question marks are (if this is the way to do it)?
Any help greatly appreciated!
Mike
MjDeck
You can access the iLogic iProperties object (which includes materials) by adding this line to your dialog source file:
Public iProperties as IiProperties
The following code should work (if you change some of the names)
	Public iLogicVb As ILowLevelSupport
	Public iProperties As IiProperties
	Private Sub Dialog1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
		For Each material In iProperties.Materials
			ComboBox1.Items.Add(material)
		Next
		ComboBox1.Text = iProperties.Material
	End Sub
	Private Sub ComboBox1_SelectedIndexChanged(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ComboBox1.SelectedIndexChanged
		iProperties.Material = ComboBox1.Text
		iLogicVb.DocumentUpdate()
	End Sub
Mike Deck
Software Developer
Autodesk, Inc.
