Accessing Windows Registry
Is there a general way to access the Windows registry for read-only purposes? I am aware of the Visual BASIC SaveSetting etc functions, which allow an application to store parameters, but these don't reach the whole registry. Is there an ActiveX component that does the job?
Paul Riley
Hi Paul,
You can write your own VB function. There are a lot of samples on the net.
Search for Windows API functions like:
RegOpenKeyEx
RegQueryValueEx
RegQueryInfoKey
My own function is already havy customized so I can't paste ready sample 😞
Adam
Take a look here: http://www.vbarchiv.net/vbapi/RegOpenKeyEx.php
"pdriley" wrote in message
news:f167331.-1@WebX.maYIadrTaRb...
Paul Riley
Adam,
Thanks. I managed to find a free registry ActiveX control. Its called WinRegistry2, or WinReg2.
I will look at your reference and try that way too.
Paul
check out iCF for a bas module that I use. It's very easy to read or write
using this module...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
news:f167331.1@WebX.maYIadrTaRb...
> Adam,
> Thanks,
> Paul
There is also Microsoft's Regobject.dll
You can get it here
http://msdn.microsoft.com/vbasic/downloads/addins/default.aspx
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Sean Dotson" wrote in message
news:E767D1858E5CA95EC5EBFADBF8C69D62@in.WebX.maYIadrTaRb...
> Sean Dotson, PE
I'm sorry did you say Microsoft?
Sean Dotson, PE
"Kent Keller" wrote in message
news:EE5DD65C58239A0047C57984C5A27485@in.WebX.maYIadrTaRb...
> You can get it here
