Accessing the data of the elements in the iam file with Inventor Api c#
hayattangercekler2
hayattangercekler2
With Inventor Api c#, is it possible to access parameter data in ipts in an assembly iam file?
Zach.Stauffer
Yes, this is fairly simple. First you have to find the correct part. You can do this with a User Selection or by searching for a string or many other ways. Once you have the ComponentOccurrence of the part you want, you can access the PartComponentDefinition and that has the user parameters in it. I have written a couple of extensions to retrieve user parameters from a PartComponentDefinition, you can use these or adapt them to not be extensions.
public static T RetrieveParameter<T>(this PartComponentDefinition definition, string name)
			var parameters = definition.Parameters.UserParameters;
			try
				var value = parameters[name].Value;
				return (T)Convert.ChangeType(value, typeof(T));
			catch (Exception e)
				return default(T);
		public static void SetParameter(this PartComponentDefinition definition, string parameter, dynamic value)
			try
				parameters[parameter].Value = value;
			catch (Exception e)
				Console.WriteLine(e);
				throw;
hayattangercekler2
Thanks for your answer but I don't quite understand what data to give for functions.
Zach.Stauffer
It's an extension method, so you use it as if it was an in-built method for that object. Since these are extensions for PartComponentDefinition objects, you'll use it like this:
PartComponentDefinition partDef = selectedComponentOccurrence.Definition //or something to this effect, depending on how you are getting the correct occurrence from the assembly
string parameter = partDef.RetrieveParameter<string>("myParameter");     //inside of the <> you put the type you want.
partDef.SetParameter("myParameter", value);
You can find more information here: https://learn.microsoft.com/en-us/dotnet/csharp/programming-guide/classes-and-structs/extension-meth...
