Accessing form in a part from an assembly
berry.lejeune
berry.lejeune
Hi everyone,
As i'm trying to make my workflow a bit easier I've come to a litte problem.
In attached screenshot (#1)  you can see the part "sketch koffer borduur" In this part I've made a sketch that includes all the dimension and outlines for my parts. There's also a form in this part that I can call up and enter all the dimensions required to make my model (#2)
Is there a way that I can call up this form with the "iTrigger" in my main assembly? Now I've got to go first into my part and then access 'Ilogic" and "forms" tab to access it.
I copied the form from my part to my assembly. But then I couldn't access the parameters anymore (#3)
Berry
Hubert_Los
You can create user parameters with the same name. Then your rule will work because it looks in the open document, for parameters with the given name. Then you can write a rule in iLogic that will copy parameters from assembly to part. This is a bit time-consuming. Or you can write your own rule in ilogic that will refer to the part. However, this is more complicated
marcin_otręba
I see two possibilities:
1. go trough select set and choose geometry part, after that you can access its properties, geometry and so on.
Dim sel_set As SelectSet
sel_set = ThisDoc.Document.SelectSet
If sel_set.Count = 1 Then
	If TypeOf sel_set.Item(1) Is ComponentOccurrence Then
	Dim doc As Document
	doc = sel_set.Item(1).definition.document  '  you can access all here
MessageBox.Show(doc.FullFileName, "Title")
	Else
		MessageBox.Show("part or assembly must be selected", "Title")
	Else
MessageBox.Show("Only one component can be selected", "Title")
Exit Sub
2. go to part trough assembly component occurrences or allreferenced documents.
Dim ass As AssemblyDocument = ThisApplication.ActiveEditDocument
Dim doc As PartDocument
For Each xdoc As Document In ass.AllReferencedDocuments
	If xdoc.FullFileName.Contains("sketch koffer borduur.ipt") Then
		doc = xdoc ' here you can access all
Next
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
berry.lejeune
My programming skills are next to nothing. Everything what I use for Ilogics and forms I gattered around the internet and this forum and then tweaked it a bit to fit my needs
berry.lejeune
When I use your rule, it gives me the location of the part on my driveScreenshot_399.png
marcin_otręba
I think i found better idea,
in your poart add rule named "show_form" for example in wchich add only:
iLogicForm.Show("write here your form name")
then in assembly you can add:
For Each comp As ComponentOccurrence In ass.ComponentDefinition.Occurrences
	If comp.Name.Contains("sketch koffer borduur") Then
		 iLogicVb.RunRule(comp.Name, "show_form")
Next
berry.lejeune
@marcin_otręba thank you very much 👍
I just had to change some names of the forms in your rule and it works!!
