Accessing All Referenced Documents Including Suppressed
Hey All,
I am currently working to write some code that will go through a full model and modify the part name of each unique component. Currently for these kinds of tasks I use a function similar to this:
Function RecursiveReview(oDoc As Document)
Dim oEachRefDoc As Document
For Each oEachRefDoc In oDoc.ReferencedDocuments
		'Recrusive call of review
		RecursiveReview(oEachRefDoc, TextFileReview, ReviewType, StudioNum)
Next
'Do Work on level
End Function
The problem that I have run into is that the Reference Documents does not include all of the suppressed files in the assemblies. Is there any way to collect all documents including these suppressed files?
JelteDeJong
Usually Inventor loads all documents that are referenced by an assembly. The problem with suppressed parts ( and assemblies) is that they are not loaded by inventor. And as you already said the are not in the referenced files lists. The way to find document that are suppressed is by looking at the occurrences in an assembly. occurrences object have an FullDocumentName. with that property you can find all referenced files and put it in a list. if you want to do something with suppressed documents the you will need to load them by opening them.
Have a look at the iLogic code.it will open all documents that are suppressed and therefore not loaded.
Sub Main()
	Dim doc As AssemblyDocument = ThisDoc.Document
	Dim refDocNames As List(Of String) = getRefDocList(doc)
	For Each refDocName As String In refDocNames
		Dim refDoc As Document = getDocument(refDocName)
		' Do the work on your document here
		MsgBox(refDoc.DisplayName)
	Next
End Sub
Public Function getRefDocList(doc As AssemblyDocument) As List(Of String)
	Dim refDocs As List(Of String) = New List(Of String)()
	For Each occ As ComponentOccurrence In doc.ComponentDefinition.Occurrences
		Dim refDocName As String = occ.ReferencedDocumentDescriptor.FullDocumentName
		If (refDocs.Contains(refDocName) = False) Then
			refDocs.Add(refDocName)
		If occ.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			refDocs.AddRange(getRefDocList(refDoc))
	Next
	Return refDocs
End Function
Private Function getDocument(fullDocName As String)
	Dim doc As Document
	Try
		doc = ThisApplication.Documents.ItemByName(fullDocName)
	Catch ex As Exception
		' you could open the files also hidden for speed inprovements
		' but Then you would need To close them also in some way
		doc = ThisApplication.Documents.Open(fullDocName)
	End Try
	Return doc
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
This actually would work perfectly fine for what I am trying to do, thanks for the help!
