Access to Datum, Surface, Feature callouts
ktucker86UDQ
ktucker86UDQ
Struggling to gain access to the above programmatically. I'd like to access text that are input to these fields on a .dwg. I've explored SketchedSymbols and SurfaceTextureSymbols to no avail. Any point in the right direction would be appreciated.
Kyle
abdullah_elq
You can access feature callouts using the DrawingNotes Object. That gives you access to:
In general, you can use the following iLogic code to find the object type for anything:
Dim x = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select Object")
MessageBox.Show(TypeName(x))
WCrihfield
Hi @ktucker86UDQ.  In addition to those objects mentioned above, there are a few newer ones available right under the Sheet object in Inventor 2024.
Sheet.EdgeSymbols
Sheet.FeatureControlFrames (available 2009)
Sheet.RevisionClouds
Sheet.WeldingSymbols
I do not believe the Datums, or the Feature Identifier Symbol have been exposed to the API yet.
And you said you have already looked into the SurfaceTextureSymbols, so I am not sure what you may have been referring to by 'Surface' in your post title.
Wesley Crihfield
(Not an Autodesk Employee)
