Hi all,
I just stared using iLogic & Inventor forms, still learning new things.
I am working on this curtain panel (Skelton based model) which contains many components to be fabricated, to make my work easy I started creating a form (attached). My question is to assess all the parts used in that assembly in the form, is can I do that.
My end goal is when I change a parameter, all the parts which are dependent on that parameter should Save & Replace to next sequence part number (eg. MM-01 to MM-02) in the file manager and
Replace the derive part ( current Skelton with the new one) (this is a story for post)
Thanks.
