Access parameters of components with models states at assembly level
vmat8888
vmat8888
I am trying to change parameters of components in an assembly, using iLogic and user parameters in assembly, to control values of parameters in components, with different models states.
For example, I have a user parameter, "Strut_Lenth", in assembly and I try to control "Lenth" parameter in one component with different model states, BUT NOT FOR "LENTH". The "Length" value in component is the same for all its different model states, but I need to be able change it at the assembly level.
I tried the two lines of code below, but both give me errors. I would appreciate your help.
Thank you.
Parameter("Slotted Strut:1", "Lenth") = Strut_Lenth
Parameter("Slotted Strut:1","
Model State1", "Lenth") = Strut_Lenth
vmat8888
Sorry, typo mistake (see below). The question of course, still stands. Thank you.
Parameter("Slotted Strut:1", "Length") = Strut_Length
Model State1", "Length") = Strut_Length
