Access file current version with ilogic
MarcoMoura9852
MarcoMoura9852
Hello All,
Can anyone explain how can I access the "file current version" propertie, with ilogic? (what is the ilogic function...)
The propertie is marked yellow on the picture.
Also, as far as I know, this propertie is only visible when i access iproperties thru windows file explorer.
Can someone help me?
Thank you.
Michael.Navara
Here is code to access some of this properties
Dim oDoc As Document = ThisDoc.Document
Dim currentVersion = oDoc.FileSaveCounter
Dim previousVersion = currentVersion - 1 ' NO API
Dim nextVersion = currentVersion + 1 ' NO API
Dim createdWith = oDoc.SoftwareVersionCreated.DisplayName
Dim lastUpdateWith = oDoc.SoftwareVersionSaved.DisplayName
Dim needsMigrating = oDoc.NeedsMigrating
MarcoMoura9852
Thank you!
