A macro that changes the iPart instance of a Drawing
JonnyPot
Message 1 of 11
JonnyPot
Hello. I have created a iPart witch has hundreds of instances and i would like to make individual drawings for all of them. I was wondering if it's possebel to create a macro scrip that when ran on a drawing changes its iPart instance, updeits it, saves it and then repites the same actions to all the other instances in the iPart.
Replies (10)
Message 2 of 11
JhoelForshav
Hi @JonnyPot
You can change the instance with the property ActiveMemberName in the DrawingView object.
Try creating a drawing of one of your iPart instances, and then run this macro.
Just remember to assign your desired directory for where the files should be saved in to the variable "oPath".
Sub iPartDWG()
Dim oDrawing As DrawingDocument
Set oDrawing = ThisApplication.ActiveDocument
Dim oPath As String
oPath = "C:\Jhoel\iPartDWG" 'Folder to save the drawings
Dim oView As DrawingView
For Each oView In oDrawing.ActiveSheet.DrawingViews
Dim oDoc As PartDocument
Set oDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oRow As iPartTableRow
For Each oRow In oDoc.ComponentDefinition.iPartMember.ParentFactory.TableRows
    If oView.ActiveMemberName <> oRow.MemberName Then oView.ActiveMemberName = oRow.MemberName
    Call oDrawing.Update
    Call oDrawing.SaveAs(oPath & "\" & oRow.MemberName & ".dwg", True)
Next
Next
End Sub
Message 3 of 11
JonnyPot
Hello. tried the Macro and i got a 2 errors. tell me if you know how to fix them
1- after it makes around 5 drawings i get a "run-time" error.
2- dispite the "For Each oView In oDrawing.ActiveSheet.DrawingViewsIt" it only updates one of the view.
Message 4 of 11
JhoelForshav
Hi @JonnyPot
Sorry, I see now that I got some operations in the wrong order in the previous code. Should have tried it first!
This one however I have tried and it worked for me 🙂 Let me know if there are any issues with it 🙂
Sub iPartDWG()
Dim oPath As String
oPath = "C:\Users\hfljf\Desktop\TestFolder" 'Folder to save the drawings
Dim oDoc As Document
Dim oFactory As iPartFactory
    On Error GoTo trynext
    Set oFactory = oDoc.ComponentDefinition.iPartMember.ParentFactory
    Exit For
trynext:
Next
    If oFactory Is Nothing = False Then
    On Error GoTo nextView
    For Each oRow In oFactory.TableRows
        Do While oView.IsUpdateComplete = False
            Call ThisApplication.UserInterfaceManager.DoEvents
        Loop
nextView:
    Next
Next
End Sub
Message 5 of 11
JonnyPot
it works perfectly thank you very much.
Message 6 of 11
JonnyPot
is it possible to convert it to auto export in STEP all the instances of an iPart. thank you.
Message 7 of 11
JhoelForshav
Hi @JonnyPot
I added a few lines to the code so that it now saves the dwg and the corresponding iPart member as a step file 🙂
Sub iPart_DWG_STP()
Dim oPath As String
    Exit For
trynext:
Next
        Loop
nextView:
    Next
    Dim oMember As PartDocument
    Set oMember = ThisApplication.Documents.ItemByName(oFactory.MemberCacheDir & "\" & oRow.PartName)
    Call oMember.SaveAs(oPath & "\" & oRow.MemberName & ".stp", True)
Next
End Sub
Message 8 of 11
JonnyPot
thank you very mutch.
Message 9 of 11
JonnyPot
Hello @JhoelForshav , sorry if i disturb you, i have a small problem with the Macro wen tryping to create drawings for iParts that contain iLogic rules. the problem being that the rules dont update, do you know any solutions, thankyou.
Message 10 of 11
JhoelForshav
@JonnyPot
I see you have already created a new thread about this issue so I'll answer there instead 🙂
Message 11 of 11
JanHalus
Excelent solution, helped me a lot! Thanks! 🙂 I have a question tho, what do I have to change to create new sheets within the same .idw, instead of sepparate .dwg files?
