3D PDF
3D PDF
manasi_patilESZTV
3D PDF
manasi_patilESZTV
I try to convert .iam file to 3D pdf using Inventor programing Api help but it is not Coverting.
Michael.Navara
Can you put your code sample and test date here? Without this information we can't help you.
manasi_patilESZTV
the Error is :'Typelib export: Type library is not registered. (Exception from HRESULT: 0x80131165)' In below code at line no 36  pdfConvertor3d.Publish(oDoc, oOptions);
public void Export3DPdf()
            Inventor.Application InvApp = mApp;
            Inventor.ApplicationAddIn  PDFAddin = null ;
            foreach (ApplicationAddIn appAddin in mApp.ApplicationAddIns )
                if (appAddin.ClassIdString == "{3EE52B28-D6E0-4EA4-8AA6-C2A266DEBB88}")
                    PDFAddin =  appAddin;
                    break;
            dynamic pdfConvertor3d = PDFAddin.Automation;
            Document oDoc = mApp.ActiveDocument;
            // Create a NameValueMap object
            Inventor.NameValueMap oOptions = InvApp.TransientObjects.CreateNameValueMap();
            oOptions.Value["FileOutputLocation"] = @"c:\temp\3DPDF.pdf";
            oOptions.Value["ExportAllProperties"] = true;
            oOptions.Value["GenerateAndAttachSTEPFile"] = true ;
            oOptions.Value["ExportTemplate"] = @"C:\Users\Public\Documents\Autodesk\Inventor 2019\Templates\Sample Part Template.pdf";
            oOptions.Value["VisualizationQuality"] = AccuracyEnum.kHigh;
            //string[] sProps = new string[1];
            //sProps[0] = "{F29F85E0-4FF9-1068-AB91-08002B27B3D9}:Title";
            //oOptions.Value["ExportAllProperties"] = false;
            //oOptions.Value["ExportProperties"] = sProps;
            String[] sDesignViews = new string[] { "Master", "View1" };
            oOptions.Value["ExportDesignViewRepresentations"] = sDesignViews;
manasi_patilESZTV
Get Error while converting
Michael.Navara
I tested your code, and the issue is in type of variable oDoc. This variable MUST be of type _Document instead of Document.
Document oDoc = mApp.ActiveDocument; //DOESN'T WORK
_Document oDoc = mApp.ActiveDocument;
manasi_patilESZTV
I try for this code but still give same error.
StKrause
@manasi_patilESZTV check if template
exists and designView "View1" exists in your assembly (lines 25 and 33 in your code).
