3D-Pdf export to same location as 3D-file
Kupiszewski_A_
Kupiszewski_A_
Hello everyone,
I'm trying to write an ilogic rule that creates a 3D PDF and saves it in the same folder (or subfolder) as the original 3D part. I've tried many things, but it just doesn't work.
Can someone please help me?
Thank you very much!
cidhelp
Hello @Kupiszewski_A_ ,
there is a VBA-Sample to export 3D-PDF:
https://help.autodesk.com/view/INVNTOR/2025/ENU/?guid=ExportToPDF3D_Sample
I created a iLogic rule from that. This rule exports the active document to 3D-Pdf (same folder as model).
You have to adjust the template filenames (line 16/18) and the names of the design views (line 34/35).
Kupiszewski_A_
hallo cidhelp!
Thank you very much It works great!
I modified the rule. It creates a subfolder for the PDF. That works too. But it remains empty.
The PDF is saved in the main folder.
Can you please take a look at it?
Thank you very much for your help!
cidhelp
you have to replace line
Dim ExportFileName = ThisDoc.ChangeExtension(".pdf")
with
Dim ExportFileName = oFolder & ThisDoc.FileName & ".pdf"
Kupiszewski_A_
It works wonderfully!
Thank you very much
