3D Path
3D Path
karthikpadamati31
3D Path
karthikpadamati31
Hello all,
I just want to know how can we make a 3d path using two 2D sketches(let say 2 splines)? Can we Create it?
Thanks in advance
JaneFan
Yes, we can create it using PartFeatures.Createpath().
Here is the description of this function:
Function CreatePath(SketchCurve As Object) As Path
Member of Inventor.PartFeatures
Method that creates a path used to define the shape of several part features such as sweep, rectangular pattern, split, etc. All other 2D and 3D curves that are connected to the input curve are obtained and used to create a Path object. The new Path is returned
Jane Fan
Inventor/Fusion QA Engineer
karthikpadamati31
Thanks for the response, Can you please send a screencast video of it?
JaneFan
For the model like this:
Here is the VBA code which can be used to test it:
Sub test2()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oLine2d As SketchControlPointSpline
Set oLine2d = oDoc.ComponentDefinition.Sketches(1).SketchControlPointSplines(1)
Dim oLine3d As SketchControlPointSpline3D
Set oLine3d = oDoc.ComponentDefinition.Sketches3D(1).SketchControlPointSplines3D(1)
Dim oPath1 As Path, oPath2 As Path
Set oPath1 = oDoc.ComponentDefinition.Features.CreatePath(oLine2d)
Set oPath2 = oDoc.ComponentDefinition.Features.CreatePath(oLine3d)
End Sub
Jane Fan
