3D arc geometry evaluator getstrokes "Type mismatch"
Jef_E
Jef_E
I'm trying to implement the getstrokes feature from the API sample. I modified it a little so the input is the first 3D sketch and the first 3D arc in it.
I also have the same problem when trying it for 2D arcs (what I really need) but the sample was for 3D arcs thats why I use this to try and explain my problem.
This is the error message produced:
System.Runtime.InteropServices.COMException (0x80020005): Type mismatch. (Exception from HRESULT: 0x80020005 (DISP_E_TYPEMISMATCH))
   at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   at Inventor.CurveEvaluator.GetStrokes(Double FromParam, Double ToParam, Double Tolerance, Int32& VertexCount, Double[]& VertexCoordinates)
   at LmiRuleScript.Main()
   at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
SyntaxEditor Code Snippet
    Dim partDoc As PartDocument
    partDoc = ThisApplication.ActiveDocument
    ' Have the user select a sketch entity.
    Dim selectObj As SketchEntity3D
    selectObj = PartDoc.componentDefinition.Sketches3D.Item(1).SketchArcs3D.Item(1)
''From here is nothing edited by me!
If selectObj Is Nothing Then On Error Resume Next Call partDoc.ComponentDefinition.ClientGraphicsCollection.Item("Test").Delete Call partDoc.GraphicsDataSetsCollection.Item("Test").Delete ThisApplication.ActiveView.Update Exit Sub End If ' Get the tolerance to approximate with. Dim tolerance As Double tolerance = Val(InputBox("Enter the chord height tolerance:", "Tolerance", "0.25")) ' Get the evaluator from the curve. Dim eval As CurveEvaluator eval = selectObj.Geometry.Evaluator ' Get the parameter extents. Dim startParam As Double Dim endParam As Double Call eval.GetParamExtents(startParam, endParam) Dim vertexCount As Long Dim vertexCoords() As Double Call eval.GetStrokes(startParam, endParam, tolerance, vertexCount, vertexCoords) ' Create a client graphics object. If one already exists, give the user ' the option of re-using it, or creating a new one. Dim graphics As ClientGraphics Dim graphicsData As GraphicsDataSets On Error Resume Next graphics = partDoc.ComponentDefinition.ClientGraphicsCollection.Item("Test") On Error Goto 0 If graphics Is Nothing Then graphics = partDoc.ComponentDefinition.ClientGraphicsCollection.Add("Test") graphicsData = partDoc.GraphicsDataSetsCollection.Add("Test") Else 'Dim answer As VbMsgBoxResult 'answer = MsgBox("Yes to add to existing graphics. No to create new graphics. Cancel to clean graphics and quit.", vbYesNoCancel + vbQuestion) If answer = vbNo Then On Error Resume Next graphics.Delete partDoc.GraphicsDataSetsCollection.Item("Test").Delete On Error Goto 0 graphics = partDoc.ComponentDefinition.ClientGraphicsCollection.Add("Test") graphicsData = partDoc.GraphicsDataSetsCollection.Add("Test") ElseIf answer = vbYes Then graphicsData = partDoc.GraphicsDataSetsCollection.Item("Test") ElseIf answer = vbCancel Then If Not graphics Is Nothing Then graphics.Delete partDoc.GraphicsDataSetsCollection.Item("Test").Delete ThisApplication.ActiveView.Update Exit Sub End If End If End If Dim coordSet As GraphicsCoordinateSet coordSet = graphicsData.CreateCoordinateSet(1) Call coordSet.PutCoordinates(vertexCoords) ' Create a graphics node. Dim node As GraphicsNode node = graphics.AddNode(1) ' Create a line strip using the calculated coordinates. Dim lineStrip As LineStripGraphics lineStrip = node.AddLineStripGraphics lineStrip.Coordinate= coordSet ThisApplication.ActiveView.Update
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Jef_E
I'm still stuck here..
Inventor 2014 SP2
danijel.radenkovic
Hi Jef,
I have tested your code and it works fine if you add "Set" in every row where is  "variable=something".
Try with this:
Option Explicit
' Draws client graphics that is an approximation
' of the selected curve.
' To use this have a part open that contains
' a 3D skech that contains curves.
Public Sub Approximate3DSketchGeometry()
    Set partDoc = _
    Set selectObj = partDoc.ComponentDefinition.Sketches3D.Item(1).SketchArcs3D.Item(1)
'    Set selectObj = ThisApplication. _
'                    CommandManager.Pick _
'                    (kSketch3DCurveFilter, _
'                    "Select 3D sketch entity")
        Call partDoc.ComponentDefinition _
        .ClientGraphicsCollection.Item _
                                ("Test").Delete
        Call partDoc.GraphicsDataSetsCollection _
        Exit Sub
    tolerance = Val(InputBox _
     ("Enter the chord height tolerance:", _
    Set eval = selectObj.Geometry.Evaluator
    Call eval.GetParamExtents _
    Call eval.GetStrokes(startParam, endParam, _
    ' If one already exists, give the user
    ' a new one.
    Set graphics = partDoc.ComponentDefinition. _
    On Error GoTo 0
        Set graphics = partDoc. _
      ComponentDefinition.ClientGraphicsCollection _
                                      .Add("Test")
        Set graphicsData = partDoc. _
    Else
        answer = MsgBox _
        ("Yes = existing. No = new Cancel. = quit.", _
            graphics.Delete
            On Error GoTo 0
            Set graphics = partDoc.ComponentDefinition _
                graphics.Delete
                Exit Sub
    Set node = graphics.AddNode(1)
    Set lineStrip = node.AddLineStripGraphics
    lineStrip.CoordinateSet = coordSet
End Sub
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
danijel.radenkovic
Here is a video screenshot.
Jef_E
Set is because you use VBA and I'm using vb.net so that is not the problem,
what version of inventor are you using?
Inventor 2014 SP2
danijel.radenkovic
Yes, I know that. I just figured out later that you are trying to modify code for ilogic.
By the way, I am using Inventor 2017/VBA7.1 on Windows10 x64.
Danijel
danijel.radenkovic
Hi Jef,
According to Mfg DevBlog, I have found something that is interesting.
http://adndevblog.typepad.com/manufacturing/2014/07/type-mismatch-error-with-vba-code-in-net.html
What I mentioned as a difference between VBA and VB.net code is in declaration of double. There is a "= {}".
