2018 ilogic change
2018 ilogic change
jletcher
Advisor Advisor
2018 ilogic change
jletcher
Not sure what to say all I want to do is scream you all screwed this up, and now will cost 5 hours of rework.
2018 should never had been released.
I'll be back when I cool down to explain.
mcgyvr
Just reserving my spot for the show... Please don't start before I get back with my popcorn.. Smiley Very Happy
I can't wait to hear this one... I'm in serious need of some big chuckles today...
Seems like someone else may need a hug too...
Mark.Lancaster
@jletcher
I fully understand you may be faced with an issue, rework or have frustration..  However this forum is not intended to preach your frustration like you just did.  There's no value added to your posting, scream, and etc..  Only to say I'll come back later when I cool down...   So I question why you thought it was important to do this and waste every ones time who ends up opening your posting thinking lets see what this problem is and I can assist.
Although in your words your implying something bad back to Autodesk (assuming that)..  But watching the wording...   Remember, this is mainly a user based forum and when you say we all screwed this up,  your implying the users of this forum did this to you.
For the future take the frustrations out of your posting..  Just don't post when your in the mood.  This is a professional site and we all deserve that (not matter if someone from Autodesk is assisting you or another user)..  Like I said we all are faced with issues here and there that may impact our environment or cause re-work..  We all see that, but the tone and words you use are not called for.   Like rule #1 of the forums (https://forums.autodesk.com/t5/community-faq/etiquette-and-ground-rules/td-p/5384757) Keep it clean and constructive  (and that applies to everyone not just you)...
Mark Lancaster
mcgyvr
@Mark.Lancaster wrote:
@jletcher
@Mark.Lancaster That was a waste of your time.. You must be new here... Smiley Very Happy
Its lunch time here.. I hope the show doesn't start before I get back...
kelly.young
Autodesk Support
Autodesk Support
Hello @jletcher it sounds like there was a change to the way iLogic is being implemented within your workflow, moving the thread to the Inventor Customization Forum for best results.
If there is an issue with iLogic changes that would be the best place to clarify the behavior and get helpful suggestions.
Please select the Accept as Solution button if a post solves your issue or answers your question.
jletcher
Just remove the thread. It is not a help issue like you said this is a place for help.
seeing it already messed up the files there is no help to change that.
thanks
