2017 Inventor professional How to scale an object in just one axis
I was triying to install SDK for inventor 2017 in order to get the option "Derived Part (Scale/Position)" under the addins tab. After I install SDK this option does not appear in the addins tab. Someone knows how can I modify and scale an object just in one axis in inventor 2017? I think this work in versions like 2012 but I dont have it.
Thank you.
Binga
You can do that using the "Direct" tool:
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Thank you! It is so helpfull, I did not know about this option!
