2011 Moving Geometry from Flat Pattern sketch space to Flat Pattern Space.
I am trying to export geometry found in a flat pattern sketch overlaid onto the flat pattern.
Since I am creating the output file manually I gather the flat pattern boundaries and bend center lines for output to a file.
When I add flat pattern sketch entities to the mix they do not overlay properly.  What matrix would I have to push the sketch entities through to get them to the same coordinates as the flat pattern?
Okay,
Looks like the SketchToModelSpace() method is what I needed.
  With oLine.Geometry
     Set sPt = oSketch.SketchToModelSpace(.StartPoint)
     Set ePt = oSketch.SketchToModelSpace(.EndPoint)
  End With
