It seems like when changing settings on the results view, any time you make a change you need to re-display the view. This is especially frustrating as changing some of the parameters seems to reset others.
Here is a typical example of my workflow:
- Set the display stress limits then apply the changes.
- Re-display the results.
- I decide I want to limit the parts I'm looking at, so I make that change in the results parameter dialog.
- Doing this has cleared the stress limits I earlier set, so I make that change in the results parameter dialog.
Changing results view parameters should not cancel the view from being displayed, or at least it should re-display the view automatically (if you were in that view when you entered the Edit dialog). Additionally, settings shouldn't just change automatically when you make other changes in the results view.
