Show only
Search instead for
Currently, there is only an option to delete all probes. If multiple probes have been selected and then there is a mis-pick, the only way to get rid of it is to delete all probes and start the selection process over.
This was posted 04-30-2019, i.e. over a year ago. Are Autodesk doing anything about the request ?. It is really irrating to a. identify the node that your after and put a probe label on, only to find you've picked the wrong node !!!. Node identifcation could also be vastly improved the query node is not that helpful.
Great suggestion. Probes needs work. Does Autodesk even care or read those forums? I have commented and voted a couple but they all seem to date more than 2 years ago.
