Von mises results too high?
reymart.laranjo
reymart.laranjo
I'd like to confirm why am I getting 85k Von mises result?
I think I've done something wrong.
thank you and kind regards,
John_Holtz
Autodesk Support
Autodesk Support
Hi @reymart.laranjo
Are you focusing only on the maximum result of 85000 MPa? 99% of the model is above the yield strength of the steel!
You are correct that something is wrong. Either the load is wrong (the applied pressure of 555 MPa = 80500 psi seems a little high!) or the design is wrong.
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
reymart.laranjo
Hi @John_Holtz ,
I intended to use that 250t I converted it into pressure which is 555.55 MPA. And check if this type of design suits it. Just kindly ignore my design that's the type we wanted.
I just wanted to know if the 85k MPA is correct. or could somebody check my model if it's correct? or I have done something wrong?
krgds,
reymart.laranjo
I found the problem my load is not correct though.
