I am having trouble viewing the result of an explicit quasi-static model.
This model has following parameters:
Under Quasi-Static Setup 1 --> Edit
- Duration= 1 sec
- Number of Timestep = 2 (Time Step = 0.5sec)
Loads:
- pressure applied on top, ramping up from 0 to 0.5 sec and remains still until 1 sec
- pressure applied on side, ramping up from 0.5 sec to 1 sec.
Analysis Options:
- Explicit Quasi-Static Step, Number of Steps to 2.
When I run the analysis , the result only shows up to 0.5 second instead of 1 second. However, the output file shows that the analysis is complete to 1 second.
Why is Nastran only showing result up to 0.5 sec instead of 1 second?
The attached is the model and .txt version of out and nas files.
PS I played around with Number of Steps and Number of Timesteps, and it seems like the result only shows up to the first increment based on Number of Steps. For example, if I set Number of Steps to 3 with total duration of 1 second, the result only shows up to 0.333 sec. How can I view the result for total duration?
