Using empirical temperature data
Jonny.Murty
Jonny.Murty
Folks, is there any way to input actual measured temperature data on a piece of equipment to work backwards to get a more accurate convection coefficient for future thermal analyses?
KubliJ
Hi @Jonny.Murty,
In theory, it is possible.  Nastran needs nodal temperature results... but you would need to interpolate all your empirical data to all the nodes in the model, even the the internal nodes.
But if you have the data, could you not hand calculate the convection coefficient?
Otherwise, the only thing I can think of is a guess and check until you reach the appropriate value.
James
James Kubli, P.E.
Please marked this as solved if your question has been answered.
Jonny.Murty
Thanks for your reply. I'll have a go at hand calculating it.
