Hello
I have some doubts about the surface contact, mainly in the difference between sliding/no separation and separation/no sliding.
Because when I define sliding/no separation between the bolts and top plate and column in linear analysis. It failed because it is a singularity in the stiffness matrix. But calculatin by non linear analysis, it solves.
When I define separation/no sliding, it solves with problems, but the tension results are not correct. The pcitures are below:
For me, the correct contact is sliding/no separation, but it isn't solve the problem.
Can you help me?
Thank you!
