- Inventor Nastran 2022.1.0.143
- Linear static analysis
- Springs are created between 2 points.
- points are connected to split surfaces using rigid connectors
- vertex data mesh controls are applied to the points to connect the spring end points to the FEA model
Deformation scale is set to Actual. Total dispalcement is correct giving the load, spring stiffness and pivoting constraint applied to the 2nd hole/pin.
One of the springs (see figure below) is moving in opposite direction of the other springs and actually apposite direction of the FEA model general displacement.
Any thoughts? @John_Holtz @KubliJ @Roelof.Feijen
Max H.
Max H.
