When I apply the remote force to a surface I get the results like in the load application but when I apply it more than 1 surface it changes the results dramatically.
I ran the test for different scenarios and it is applying this remote force individually.
Is there any way to apply this remote force to multiple surfaces as a total force?
P.S.: I searched the forum and found similar questions but couldn't see any answers.
Nastran 2020 Version 14.2.0.101
Inventor Nastran Version 2020.2.0.390
Inventor Nastran 2020
Solved by John_Holtz. Go to Solution.
In version 2020 (and newer), you need to apply the remote force to one surface at a time. See the article Results of an analysis are unexpected when using a remote force in Inventor Nastran.
In general, searching on knowledge.autodesk.com is the best place to start when searching for issues with an analysis or the Inventor Nastran interface. The results found include sources written by technical support, forums, and documentation.
