Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Probes staying on screen after "Delete All Probes"
CamperUnhappy
CamperUnhappy
I'm working on a very large FEA analysis right now and the interface is paaaaaaainfully slow.  With that I'm experiencing a new and fun problem and it has to do with placing probes on results.  When I clear all the probes off the display with the button on the toolbar, there is still sometimes 1 probe left on the screen.  In fact it's still there even after unloading the display results.  In order to solve the issue, I have to close Inventor and re-open everything again.
I am working on my local drive, and my PC specs are as follows:
Windows 10 1903
i7-8700 @ 3.2 GHz
16 GB of RAM
Nvidia GTX 1060 6 GB (Updated drivers)
500 GB SSD NVME OS drive
It seems like it happens if you hit ESC to cancel while your mouse is hovering over your model.  It's quite repeatable.
AndrewWeighell7348
I would also be interested in a solution.  I have just noticed exactly the same thing.  2021 latest.
It is difficult to put a finger on.  It seems something to do with using the probes.
I also have a zombie probe result which can neither be selected nor deleted, and persists through ADSK Nastran starting, stopping and re-running.
Like Star Wars The Phantom Menace, it will always be there. It will never go away.
And when I try to make new probes, Inventor crashes. Cool and normal!
John_Holtz
Autodesk Support
Autodesk Support
Hi @Anonymous
Sorry to hear about the crash.
  • What version of Inventor are you using?
  • Did you submit the crash report? If so, do you have the report number?
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius 😉
