Multiset Animation Error
edan.shalev
edan.shalev
when I'm running explicit dynamics analysis, I'm having issues with multiset animation.
Whenever I perform a multiset animation, the animation shows weird shapes on the screen.
I'm able sometimes to solve it if I use a deformed scale instead of actual, but than it doesn't show the actual displacements.
If I scroll on the results of each time step, one by one, the view looks OK.
Roelof.Feijen
Hello @edan.shalev ,
I have taken a look at your model.
Can you explain what the analysis is about? If have got the feeling that the model is statically constrained, but there is also velocity.
What is the Max. Displacement at the end of your Analysis? Is it small are large compared to the model size?
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
edan.shalev
Hi Roelof
thanks for the reply
The intention is to quickly simulate an impact by applying an initial velocity to one component while the other is constrained.
I actually found a solution for my problem in the below post:
https://forums.autodesk.com/t5/inventor-nastran-forum/multistep-animation-display-problem-in-explici...
