Missing parameter in Design Optimization Processor Parameters
natanaelfh
natanaelfh
Hi, I am trying to do a topology optimization with a manufacturing constraint of milling, preferably in 3 and then 5-axis.
On this site is says MILL is an option in TOPTMANCONSTR.
https://knowledge.autodesk.com/support/inventor-nastran/learn-explore/caas/CloudHelp/cloudhelp/2021/...
In this video with Inventor 2018 it is an option
https://youtu.be/T2iAwscwf8k?t=4679
This seems strange.
Is the only solution to use an older version of the software?
Thanks in advance for any clarification.
Roelof.Feijen
No, it's not the only solution to use an older version. Note that Topology Optimization has never been officially implemented in Inventor Nastran (previous named Nastran In-CAD).
It has been implemented in Fusion 360.
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
natanaelfh
Thank you for the reply. I have tried the Generative Design in Fusion360 and it works great, however I am trying to compare different solutions. If there is no other way of enabling the feature in Inventor 2021 I will install the older software.
But again thanks for the reply.
