Hello @g.ceruti,
I will try to explain what Andrew meant. If you open up the dialog box for Load in nonlinear static analysis, you will notice that you do not have a way to input the load as a time variant i.e. F(t) using table. Instead you enter the final load value. With nonlinear static analysis, the load is applied in a "ramp" form. For example, if you apply a load of 1N, a portion of the load is applies at each time step, until 100% of the load is applied by the end of the analysis. You will see "OUTPUT SET: INCR x, Load=y" in the bottom left of the work area when nonlinear analysis is run, where "x" and "y" represent the increment number and proportion of the load applied, respectively.
So if you want to model releasing of a load (i.e. unloading) in nonlinear analysis, you need to add a second subcase study with that load removed. The analysis will then gradually remove the load in a ramp form in that subcase study. The only problem is, you need a load defined in a study or the analysis will not run and you will get the message "No load exists within a subcase". To get around this issue, Andrew applied dummy thermal load, allowing the "force" load to decrease to zero.
For more information on how load is treated in nonlinear analysis, please refer to the article below for reference.
"How do subcases function in a non-linear solution type in Nastran"
Shigeaki K.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
