Linear static analysis Safety Factor missing in Generate Report
RadoG
RadoG
How to show Safety Factor in Generate Report
John_Holtz
Autodesk Support
Autodesk Support
Hi @RadoG
I do not generate a report very often, so I do not know what is included by default. I think the Safety Factor plot is never included, and there are no options within the report wizard to add custom images to the report.
The report is created as an HTML file. You need to use a program that will edit an HTML file and add your own custom images of the Safety Factor (or any other results of interest).
John Holtz, P.E.
Global Product Support
If not provided already, be sure to indicate the version of Inventor Nastran you are using!
"The knowledge you seek is at knowledge.autodesk.com" - Confucius šŸ˜‰
RadoG
Safety Factor missing in Generate Report  Inventor Nastran  Version 2022.1
