Latest Updates | New Knowledge Network Articles | Nastran
Azmeera.M
Alumni Alumni
Azmeera.M
Question: Where can I find a list of the latest Autodesk Knowledge Network support solutions that were created and/or updated for Nastran?
(List appears in chronological order)
 Subscribe to receive updates for new Nastran Knowledge Network articles.
For more updated solutions, also check out the AutodeskHelp Blog!
Azmeera M.
Autodesk Employee
Azmeera.M
ARCHIVE
January 2016
Error E5000 when running Nastran Analyses with PSS DECOMPMETHOD
Material cards accepted for a PCOMP card with solid elements in Nastran
Does a 16gb memory limitation exist for Autodesk Nastran
February 2016
Error: “FATAL ERROR E5004: STIFFNESS MATRIX SINGULAR OR NON-POSITIVE DEFINITE” when running analysis...
March 2016
Choosing different solver to reduce runtime in Nastran In-CAD
Linear contact solution provides unrealistic displacements
Is solid element relative stress error output from Autodesk Nastran accurate
Thermal conductance input is not available in FEMAP for Autodesk Nastran
April 2016
Error: “FATAL ERROR S1117: INTERNAL ERROR DETECTED IN MODULE” in Autodesk Nastran In-CAD
Nastran In-CAD 2017 support for Solidworks
Warning T2061: Unreasonable Material Data
May 2016
Adding loads to mesh entities
Fatal Error T2135 when running impact analysis
Nastran Editor does not open
Product Deployment 2017 - How To fix a User License Deployment that was installed incorrectly
June - July 2016
Contact stresses localized to single nodes for cylindrical contact
FATAL ERROR T2010: ID OUT OF ALLOWABLE RANGE (1-99999999) in Autodesk Nastran
Nastran 2017 installer doesn’t have the Create Deployment option
August 2016
Solid results not available in FNO for CPENTA only mesh in Autodesk Nastran
What does WARNING T2217 indicate when running an Autodesk Nastran simulation
September 2016
Contact results in elements having compressive forces in Nastran
Error: “Fatal error T2021: Invalid Property Data in Field” in Nastran
Error: “Fatal error T2024: Entry Produces a Zero Magnitude Vector” in Nastran
Error: “Fatal error T2044” in Nastran
Error: “Fatal Error T2054: Duplicate Grid Point Reference not Permitted for Element Type” in Nastran
Support for Direct Matrix Abstaction Programming (DMAP) in Autodesk Nastran
Warning G009: elemtype ELEMENT id HAS SINGULAR GEOMETRY in Nastran
Which material card is appropriate for an solid orthotropic in Nastran?
Azmeera M.
Autodesk Employee
