Hydrostatic Pressure on the wall of Swimming Pool Open to Air
JeffW2026
JeffW2026
I have posts and answers on this topic, but not sure if my situation has been covered and explained. The help only has one example for a liquid in a tank, which does not apply here. I am applying hydrostatic pressure on an acrylic panel that will be set in the  wall of a swimming pool, in order to determine the thickness of the concrete and required rebar...SO, I define the hydrostatic pressure on the concrete wall & acrylic panel, the point on the surface, direction where the depth varies, and I add 14.7 psi for atmospheric pressure and get results.
The problem is that I am an order of magnitude greater deflection than the acrylic panel manufacturer. The question is, should the surface pressure be 14.7 psi or 0 psi?
Thank you anyone who can help me understand how the surface pressure is implemented in Nastran.
-Jeff
JeffW2026
Does anybody on the forum know the answer to the question? Should "Surface Pressure" should be 14.7 psi or 0 psi when loading the wall of an outdoor swimming pool?
Jeff
John_Holtz
Autodesk Support
Autodesk Support
Hi Jeff,
The "Surface Pressure" should be 0 psi. The atmospheric pressure (14.7 psi) is acting on all side and cancels out.
Another way to think of it is this: The water pressure is 0 psi at the top of the fluid and increases as you go down. If you include the atmospheric pressure, the water pressure would start at 14.7 psi at the top of the fluid and increases as you go down.
Hope this leads to more accurate results.
John
John Holtz, P.E.
Global Product Support
Autodesk, Inc.
If not provided, indicate the version of Inventor Nastran you are using.
If the issue is related to a model, attach the model! See What files to provide when the model is needed.
